my new baby is alive!
Old Jul 2, 2007 | 02:07 AM
neoncrazy101's Avatar
neoncrazy101
Default my new baby is alive!
well she runs like a charm. only problem is a slight overheating problem i think. within 10 min. her valve cover got WAY to hot. i just changed her head gasket and yes i did put fluid in the radiator. it took the fans about 15 min. to turn on and it didn't do squat. what do u think it could be? i know i put the head gasket on right. but could there be something
Old Jul 2, 2007 | 05:29 AM
racerx55's Avatar
racerx55
Default RE: my new baby is alive!
how hot is way too hot, did you look at a gauge?
engine usuallyrun hot enough to burn you and 10-15 minutes is normally the time it takes to heat it up to 225 for the fans to come on.
Old Jul 2, 2007 | 06:43 AM
pimpberetta's Avatar
pimpberetta
Yeah, generally you shouldn't judge your engines temperature by the valve cover. I appologise if thats not what you mean't.
Like Racer said, everything you've said sounds quite normal.
