Aobe in my turbo setup? code #52
Old Jul 2, 2007 | 03:39 PM
turbodneonracer96's Avatar
turbodneonracer96
Default Aobe in my turbo setup? code #52
Well i got my car runing better, the Tps sensor was bad! So then i tried using a missing link. Well that didnt work cause it gave me a code #13. So then i reinstall my Aobe. I got only 2.5 psi of boost and no problems. I let the car sit for 20 min. Then i go to start it again. Now it runns ok for awhile, i gave it some throttle it came back to idle. Then the CEL comes up and i check the codes getting a #52. So i was wondering if the Aobe would be set wrong will it make the car run rich.
If so does anyone know how to set it.
Old Jul 2, 2007 | 05:42 PM
hnda8r's Avatar
hnda8r
Default RE: Aobe in my turbo setup? code #52
Dang man, you rides all #$$#ed up!!!! [sm=icon_rofl.gif]
J/K, I cant wait to see that thing when its all set.
Old Jul 2, 2007 | 09:13 PM
NEONRT98's Avatar
NEONRT98
If your running turbo you want to run a little rich. Its better to run rich than to run lean
