HELP PLZ
Old Jul 10, 2007 | 10:28 AM
jakedlee16's Avatar
jakedlee16
Default HELP PLZ
i have a few problems with my car
Its a 95 SOHC ... theres a small hose coming from the intake and goes down behind the throttle body .. i broke it right behind the throttle body , i thought it might be a vacuum line but it seems rather large for a vaccum line .. however its not making a difference tht i can tell .. what is it ? even before that tho my car has trouble starting sometimes it starts right up .. but most of the time i have to play with the gas to get it up ... i was thinking maybe the fuel pump but it runs perfectly fine after i get it started ..
Old Jul 10, 2007 | 06:15 PM
jakedlee16's Avatar
jakedlee16
Default RE: HELP PLZ
bump?
Old Jul 10, 2007 | 07:11 PM
NYG's Avatar
NYG
Does the other end of the Hose connect to the top of your valve cover? or does run over above your engine mount on the passenger side of the car?
Old Jul 10, 2007 | 09:17 PM
HabitatHxC's Avatar
HabitatHxC
NYG you are thinking of the same thing, On earlyer years that goes right behind the intake manifold. I think its for PVC but I could be wrong.
Old Jul 10, 2007 | 09:56 PM
95neonriceeater's Avatar
95neonriceeater
it might be!!!
does it connect to the intake hose?
if it is it's the hose that reads the air from the intake
i broke mine off when i was taking off the stock hose for my cold air intake
it's a PITA to get off and on without taking everything apart
but doesn't take too long...
Old Jul 11, 2007 | 10:22 PM
jakedlee16's Avatar
jakedlee16
ORIGINAL: 95neonriceeater
it might be!!!
yeh thts what it is but do i need it becuz its seemd to make no differecne and its been about a week now so?>
