headlight switch shuts car off!!! help!
Old Jul 15, 2007 | 11:40 PM
pssssst's Avatar
pssssst
Default headlight switch shuts car off!!! help!
wowww, car is still finding ways not to wanna run properly.... now whenever i open the door my headlight relays in the fuse panel in the dash are clicking rapidly until i turn the **** completely left and shut the dome light off... then when the car is started i pull the headlight **** and it stalls the car... what is going on???? any help is appreciated thanks every1
Old Jul 16, 2007 | 12:18 AM
racerx55's Avatar
racerx55
Default RE: headlight switch shuts car off!!! help!
check all your fuses, check all your ground wires, and check the positive wire that goes into the fuse / relay box under the hood.
if you lose body ground cars tend to go nuts like that.
Old Jul 16, 2007 | 01:18 AM
protivakid's Avatar
protivakid
ORIGINAL: racerx55
True story, I forgot to reconnect a ground to the car's body before, after removing it, and as I drove down the road, each time I put on my left turn signal my wipers also came on lol.
Old Jul 16, 2007 | 01:53 AM
racerx55's Avatar
racerx55
i lost the positive battery connection on my old truck, it would start(buring the terminal to hell in the process), but when i hit the brakes or tuned anything on it would die and evrything would go crazy in it.
