Cluster Problem
Old Jul 16, 2007 | 09:09 PM
2424AJD's Avatar
2424AJD
Default Cluster Problem
Hey everyone
I have made a bone head move, I had removed the needles on my cluster when I had repaired the tripometer. Is there a way to reset the clutser or will I have to just look fo ra replacement unit. Cluster is on a 1998 neon sport 2.0L DOHC.
Old Jul 16, 2007 | 10:23 PM
das2123's Avatar
das2123
Default RE: Cluster Problem
Fill up the tank and set the gas needle to full. If you have a tach cluster, the RPM idle should be between 800-1000 RPM.
