Questions
Old Jul 16, 2007 | 11:27 PM
rsheppick's Avatar
rsheppick
Default Questions
Is it normal for the exhaust bolts which hold it on that have a spring around them to break while trying to remove them???
Also, I found that the heat shield and a few of the bolts which hold on the exhaust manifold were simply gone...
Anyone have any tips as far as what to do once I remove the head... I am planning on sending it to a local machine shop but I'm not quite sure what else to really do since this is my first "Car" not a 4 stroke 4 wheeler...
After several hours I have removed timing belt, water pump tensioner and pretty much all of that crap I feel like I have pretty much torn the whole motor out.
[/align]
Old Jul 17, 2007 | 07:08 AM
spudsterier's Avatar
spudsterier
Default RE: Questions
it is normal for those bolts to be broken or missing.....the heat gets to them and they just kinda sieze up
Old Jul 17, 2007 | 02:03 PM
racerx55's Avatar
racerx55
dont forget you SHOULD get new head bolts before putting it back together. toruqe to yeild bolts dont always stretch a second time without breaking.
of course get the MLS gasket for it.
what year and engine is your car
Old Jul 17, 2007 | 03:20 PM
Aerorat's Avatar
Aerorat
I have found bolts like the heat shield put some gasket sealant on the threads. The exhaust bolts did you shoot them with WD-40 or some kind of penetrating oil
Old Jul 18, 2007 | 01:47 AM
rsheppick's Avatar
rsheppick
na just went ahead and unscrewed them. :-) Maybe thats why...
