newbie help
my 95 dodge is throing the fallowing codes im inexpierneced but would like to fix my self due to a wanting to learn and a lack of money can anybody fallow up with some tips for the fallowing codes
11 Timing belt skipped 1 tooth or more from initial learned value, Intermittent loss of either camshaft or crankshaft position sensor, No crank reference signal detected during engine cranking
12 Direct battery input to PCM was disconnected within the last 50 key-on cycles
21 02s sensor problem (oxygen sensor), upstream or down stream
22 Engine coolant temp sensor out of range
25 Idle air control motor circuits, target idle not reached (+/- 200),vacuum leak found
32 EGR system failure?
thanks for the help
if any body needs anyhelp with computers or networking please let me know
thanks for the help
11-Check your sensors and wiring to the sensors. Pull them and make sure they are clean and free of debris. Also inspect the timing belt. How does the car run?
12-nothing to worry about
21-more than likely it's your upstream sensor failing or has a wiring problem. Sensor may need to be replaced.
22-inspect sensor and wiring. May need to be replaced
25-pull the IAC and clean it up real good.
32-EGR valve is probably stuck open. The EGR valve and transducer should be replaced as one.
It would help if you got the car scanned and got the "P" code to narrow down your problems.
