here is finally a video of the r/t running
look at spud now. dam. hot girl in the seat ofhis sweet car A+
... dont run it to much for a week or so till you break it in good. it would suck to have all that get fouled up because of something like that. gratz on getting it running though. sounds nice too even on them stock cams
ORIGINAL: kris95neonspt
i was looking thru your profile wtf did you do to that rod and your r/tit looks like your ball joint broke and the wheel fell off.
- the pic of the red r/t in the gallery was after i clipped a semi trailer at about 90mph....went to pass on a foggy day and ended up being another truck comming toward me.....i hit the brakes to fall back behind the semi i was passing, well the semi hit the brakes too....when i went to get back in my lane i clipped the back bumper of the trailer.....the bumper went through part of my fender and into the frame rail which left a hole the size of your fist.....when i hit the trailer i spun out in the car and ended up spinning a few times in the middle fo the road at 90mph (kinda scarry)....between hitting the bumper and spinning, i ended up breaking off the part of the controll arm that hold the ball joint, broke a fog light, broke the headlight, messed up the fender and bumper, broke 2 rear strut mounts, blew out one of my struts, broke an axel, and broke the top of the spindel where it connects to the strut....only thing holding on the tire and brake assembly was the tie-rod
Jr.
i think my wiring problem was because i clipped a wire in the engine harness that i shoud of kept there..once i hooked all the original plugs back up it worked fine
neonracer.
yeah i had the rims and tires on the dakota for a while....i just left the perellis on there...i havent even messed with the truck yet
boxer,
you cant really get that sound unless you have a turbo...
i plan on getting the car outside maybe today or tomorrow and i will get a better video, the exhaust actually sounds alot better in person then in the video...too much background noise..mostly from my dog
i do plan on taking it easy on the car for a while....i did turn the boost up to about 10psi though.....after a week or so i will crank it up to about 20psi
the driver is just my wife.....2 years this september....i cant complain though since she hasnt had too much of a problem with me spending about $6000 on this car in the past 3 monthes
yeah i was really excited......but wumthin is telling me that i cant drive it[&:]
after i finally get the motor in and running i find out that i need a rear brake caliper........got a new caliper yesterday and while im bleeding the brakes i find out that one of my steel front brake lines has a crack in it and is spitting fluid everywhere......luckily i have another one i just need to put on.....and i need to get a new crank sensor O ring......hopefully i can drive it today
yeah i think im gonna go mess around with it for a few minuites before i have to go to work....then hopefully i can finish it up after work
i look up to your r/t
