HELP ASAP!! Gear Selection**fixed**
Old Jul 24, 2007 | 09:33 PM
coolhead64's Avatar
coolhead64
Default HELP ASAP!! Gear Selection**fixed**
I cant select 1st, 3rd, or 5th.
2nd, 4th, and reverse works perfect.
Old Jul 24, 2007 | 09:47 PM
spudsterier's Avatar
spudsterier
Default RE: HELP ASAP!! Gear Selection
what were you doing when this happened????
might wanna check and make sure that nothing is binding up the selector lever on the tranny
Old Jul 24, 2007 | 09:49 PM
coolhead64's Avatar
coolhead64
well they changed the timing belt today, but i was just leaving cvs and i went to neutral at the stoplight and that was it
Old Jul 24, 2007 | 10:02 PM
coolhead64's Avatar
coolhead64
ok i fixed it
Old Jul 24, 2007 | 10:05 PM
coolhead64's Avatar
coolhead64
one of these "only me" things, the power distrib. cover was loose and apparently i hit a bump just right to knock it off and wedge it between the cable and trans.
Old Jul 25, 2007 | 07:11 AM
spudsterier
well atleast you fixxed it
Old Jul 25, 2007 | 12:59 PM
das2123's Avatar
das2123
Great story
