Alignment woes
Old Jul 27, 2007 | 11:42 AM
unclemike's Avatar
unclemike
Default Alignment woes
I put new strut kitson my 1998 Neon then took it for an alignment today. Everything worked out except the right rear. The tech said it looks as if a previous owner slid it into a curb and bent the long thru bolt that secures the control arms to the frame. He said the frame looks to be tweaked a litle too. As it is tire waer shouldn't be a problem but it's not perfect, the toe and thrust angle are off. I have a new bolt and washer coming from the local Dodge dealer Monday. Hopefully that will get the right rear tire a little closer to specs if not in spec. Anybody else have this problem and if so what other fixes are there? The way the alignment tech talked this is a common problem when you slide a rear wheel into an unmovable object.
Old Aug 8, 2007 | 12:55 AM
unclemike's Avatar
unclemike
Default RE: Alignment woes
I got the bolt that holds the control arms to the rear crossmember it'sabout a foot long. No wonder it bent.
Old Aug 8, 2007 | 08:16 AM
das2123's Avatar
das2123
Did you get the "crash" bolts from the dealer?
