Thermostat replacment...
Old Jul 30, 2007 | 10:44 PM
tallicagolf's Avatar
tallicagolf
Default Thermostat replacment...
Just did the timing belt and water pump on my brothers 96 neon sohc. I took it for a test drive and the it started to overheat after a while. Im wondering if it could possibly be the thermostat now needing replacement. I checked for leaks and found none, and coolant is full. Anyone have any suggestions? Also I havent looked because its dark now but can anyone tell me where the thermostat is located? Thanks
[align=left] [/align]
Old Jul 30, 2007 | 10:50 PM
neoncrazy101's Avatar
neoncrazy101
Default RE: Thermostat replacment...
thermostat is located on the passenger side of the car, next to the intake manifold. behind the radiator cap. just take off 2 bolts and you're there.
Old Jul 30, 2007 | 11:25 PM
Jr. Mechanic's Avatar
Jr. Mechanic
What he said, oh and, here is a pic:
Old Jul 31, 2007 | 10:12 AM
jt46324's Avatar
jt46324
Im doing a cooling system tune-up next weekend, what kind of thermostat should i put in it.
The guy at autozone said they recommend high-temp for neons. Is that thye one i should get???
Old Jul 31, 2007 | 10:47 AM
das2123's Avatar
das2123
ORIGINAL: jt46324
Feel free to, but you don't need a high temp one. Get a new radiator cap while you are at it.
Oh, and here is a decent how-to...
http://www.autozone.com/servlet/UiBr...3d80198b25.jsp
Old Jul 31, 2007 | 12:53 PM
neoncrazy101
i got the hightemp one only because it was the only one they had[:@] and i needed one.
Old Jul 31, 2007 | 01:08 PM
tallicagolf
Thanks guys, I'm going to go change it out right now hopefully thats the culprit.
Old Aug 16, 2009 | 11:38 AM
elektros75's Avatar
elektros75
at what temperature does the thermostat begin to open? and what temp does it open fully at?
Old Aug 16, 2009 | 01:37 PM
justinsanders's Avatar
justinsanders
i hate thermostats and i dont use them...ever. that was the cause of my friends cracked block and my blown head gasket. and no it doesnt run any colder than all of your motors with thermostats. it runs at the exact same temp. i just have my rad. fans wired to a toggle switch on my dash and i turn them on and off as needed.
