switching wiring harness sohc to dohc
Old Jul 31, 2007 | 01:01 AM
rgdk's Avatar
rgdk
Default switching wiring harness sohc to dohc
possible to swtich a 97' wiring harnesssohc to dohc.
Old Jul 31, 2007 | 01:06 AM
Jr. Mechanic's Avatar
Jr. Mechanic
Default RE: switching wiring harness sohc to dohc
Yes, as long as they are both 97, im confused though, are you doing a DOHC swap or putting a sohc harness on a dohc or what? I know the only real difference is the coolant temp sensor is in a different place on the dohc, but that is only like two or three wires to splice, I just put a 98 dohc harness on my 97 sohc and I had to do more splicing because people told me that it was the same for diffent years, but I guess I misunderstood them.
Old Jul 31, 2007 | 01:14 AM
rgdk's Avatar
rgdk
switching a sohc harness to a dohc.
Old Jul 31, 2007 | 01:16 AM
Jr. Mechanic
Yeah, it will work, like I said, you just have to extend the coolant temp sensor, and that should be it.
Old Jul 31, 2007 | 01:23 AM
rgdk's Avatar
rgdk
it's a neon someone selling and all it needs is a harness. they put some work into it and there selling it for 500.
Old Jul 31, 2007 | 10:10 AM
das2123's Avatar
das2123
ORIGINAL: Jr. Mechanic
The DOHC harness is longer, so he shouldn't need to extend the wires. If he had a SOHC and putting a DOHC head on there, then the extended wires would be necessary.
Old Jul 31, 2007 | 01:17 PM
Jr. Mechanic
ORIGINAL: das2123
No, you still have to extend it because it is in a different place, I dont even have mine hooked up right now because it wouldnt reach.
