wheel bearing how to
Old Aug 5, 2007 | 01:05 AM
12 volt's Avatar
12 volt
Default wheel bearing how to
So iv'e decided to change my wheel bearing and have gotten stuck at one point. After i removed the front left wheel, i removed the caliper, rotor, cotter pin, and large nut.Then i proceeded to pull on the wheel hub without it moving at all. Am i missing something?? Thax for the help and i am looking forward on sharing my electric neon stories with the forum.
Old Aug 5, 2007 | 02:18 AM
Jr. Mechanic's Avatar
Jr. Mechanic
Default RE: wheel bearing how to
The bearings have to be pressed out of the hubs and the new ones need to be pressed in, find a shop and they should do it for about $20 bucks.
Old Aug 5, 2007 | 02:30 AM
12 volt's Avatar
12 volt
so i guess i have to remove the the entire strut assembley. i was planning on useing anouther bearing form a prats car that i have but i guess thats out of the question sincethe baring isa close tolerance fit. i did a search but couldn't find any writeups on this porcedure.
Old Aug 7, 2007 | 02:42 AM
12 volt's Avatar
12 volt
bump
Old Aug 7, 2007 | 10:11 AM
NYG's Avatar
NYG
You can try a Hub Shark
I did use a friends at the track one time - worked well - just prefered using a machine shop!
Old Aug 8, 2007 | 01:45 AM
12 volt's Avatar
12 volt
aahhh...... thank you for the info. i was kinda trying to avoid alot of work, but seeing as the hub shark is out of my price range. i guess the shop is going to be the best option.
http://www.mytoolstore.com/oldforge/olf06.html
Old Aug 8, 2007 | 01:50 PM
NYG's Avatar
NYG
ORIGINAL: 12 volt
I agree - but when you are at the track on a Sunday - its nice to have friends that have one!
Otherwise I do the Machine Shop routine myself
If you watch Ebay - occasionally you can find one for half price (Used)
