question
Old Aug 5, 2007 | 11:37 AM
IzDatAneon's Avatar
IzDatAneon
Default question
I know this is probably a dumb question but i need to know the answer if someone can help me out..I'm having so much trouble swapping my sohc out to a dohc engine..1 because i have a 95 plymouth and bout a 97 engine so i ran into a problem there..but anyway my question is i found a 95 dohc eng in a sebring and basically i wanted to know if those sensors and harnes will fit on my engine?? because the engine is reverse from the one thats in the neon..if anyone knows the answer to this please let me know...thanks...
Old Aug 5, 2007 | 11:24 PM
neoncrazy101's Avatar
neoncrazy101
Default RE: question
if their swapped...aka its probably the Mitsub. engine in the Sebring then no i dont think they will.
Old Aug 6, 2007 | 07:08 AM
IzDatAneon's Avatar
IzDatAneon
The sensors should work, just not the harness...correct???
Old Aug 6, 2007 | 08:45 AM
das2123's Avatar
das2123
It uses a different PCM so the sensors may be different as well. Call a parts store and have them check the part#'s and see if they match.
