knocking from real wheel
Old Aug 7, 2007 | 02:27 PM
civiceater88's Avatar
civiceater88
Default knocking from real wheel
i have knocking noise coming from my rear wheel when my car i loaded down and u go around a corner anybody have any idea
Old Aug 7, 2007 | 06:40 PM
civiceater88
Default RE: knocking from real wheel
any idea
Old Aug 7, 2007 | 07:05 PM
spudsterier's Avatar
spudsterier
maybe a bad rear strut mount????
Old Aug 7, 2007 | 08:27 PM
civiceater88
well its more of a clunk sound when i go around corners and it only does it around corner
Old Aug 8, 2007 | 01:07 AM
unclemike's Avatar
unclemike
You didn't say if the knocking noise is related to wheel rotation or suspension travel as you corner.
I just replaced the struts on my 1998 because there was a clunking noise coming from the rear on rough roads. Figured it was a strut bearing going bad. When I moved the trunk liner out of the way and popped the rubber cap off the rear strut towers the passenger side had rust in it. A sign that the rubber isolaters were failing and letting water in. You could try that.
P.S. Anybody know how to smooth the wrinkles out of the trunk liner?
Old Aug 8, 2007 | 09:34 PM
IzDatAneon's Avatar
IzDatAneon
do you have custom wheels??? I know when i put my 18's on my car it started doing the clanking and banging noise because the wheel was actually rubbing against the torsion bar..
Old Aug 9, 2007 | 02:57 PM
civiceater88
i do but they are only 16s im thinking its a bad strut mount or bad sway bar bushing
