Engine Cut Out
Old Aug 17, 2007 | 09:51 PM
puzzlefaerie's Avatar
puzzlefaerie
Default Engine Cut Out
I am having a problem that even my mechanic is having a hard time figuring out. I have a 1995 neon sport and when I reverse or take off then engine starts to cut out on me. They have checked the head gasket and it is intact. They went throught the computer and it said that nothing was wrong so they checked all of my sensors and the MAP sensor was reading incorrectly so they have replaced that and then drove it a buch of times and it was running fine so I paid for that and drove off. Not 2 blocks down the street it started to cut out on me again. The fuel filter has also been replaced. Has anyone else had this problem or do you have an idea what the problem might be. Any suggestions would be greatly appreciated.
Thanks !!!
Old Aug 18, 2007 | 08:48 PM
NYG's Avatar
NYG
Default RE: Engine Cut Out
check your Wires for the fuel pump where they pass by your exhaust Manifold - Mine did that and I had the hardest time finding it.
Old Aug 19, 2007 | 05:16 AM
racerx55's Avatar
racerx55
check th spark on the coil and replace the wires, i just had one that would do that same thing, the wires were arcing inside the valve cover and pretty much burnt up the coil
also check the connection at the TPS
Old Aug 20, 2007 | 02:34 AM
boxerjl2's Avatar
boxerjl2
hey i had the same problem it turned out to be my rear motor mount bobble strut...
well atleast it sounds like the same problem when i went to go fast from stand still it fell like the engine fell out
but i dont think your haveing the same problem idk
