tweaking the engine
Old Aug 21, 2007 | 02:51 AM
12 volt's Avatar
12 volt
Default RE: tweaking the engine
yeah.... he was saying something about ignition spark.
you know form personal experiance?
Old Aug 21, 2007 | 08:23 AM
spudsterier's Avatar
spudsterier
there is no reason for a few ground wires to add 16hp.....atleast on a cheap neon
if you wanna get better groun for the spark then just run 1 thicker ground wire to the coil apck
Old Aug 21, 2007 | 10:41 AM
estneon's Avatar
estneon
i like apex i might get one just to have one[&:]and the only real short shiftersarehurst and some one i can't remeber the name...a egr block off might give you 1hp if your lucky
Old Aug 21, 2007 | 12:35 PM
das2123's Avatar
das2123
https://dodgeforum.com/m_298810/tm.htm
Old Aug 21, 2007 | 01:42 PM
12 volt's Avatar
12 volt
what does that mean?
most neons don't really cost that much.
Old Aug 21, 2007 | 01:58 PM
estneon's Avatar
estneon
a poor unloved never taken care of neon
Old Aug 21, 2007 | 08:59 PM
spudsterier
im saying that on a regular old neon, a grounding kit wont make very much of a difference at all....but if the car was all moded and was equipped with a high voltage ignition system then it might do a little....but i still dont see any reason for there to be a 16hp increase
Old Aug 22, 2007 | 01:49 AM
95neonriceeater's Avatar
95neonriceeater
you wanna get over 16whp with one mod?
get one of those APC stickers
Old Aug 22, 2007 | 02:03 AM
neonracer1010's Avatar
neonracer1010
forget APC ust get one that says type r and thats like 8475849whp
Old Aug 22, 2007 | 07:54 AM
spudsterier
ORIGINAL: neonracer1010
how the hell did you come up with that number???? i would of only guess about 8475840whp
i dont see getting over 16whp with only 1 mod......let alone a few thicker wires
