Best Repair Manual + Steering Vibration
Old Aug 20, 2007 | 05:56 AM
cerebral_mamba's Avatar
cerebral_mamba
Default Best Repair Manual + Steering Vibration
I just purchased a used Neon 1997 Highline Sport Coupe and have the following questions:
1. I want to install an autostart and will need to remove the dashboard paneling, steering covers etc.. For that and otherwise, which is the best repair manual to purchase?
2. At speeds over 60 MPH, the steering starts to vibrate! The vehicle goes dead straight even when I take hands off the steering, but there is a lot of vibration.. what could be the possible issues?
3. ORIGINAL QUESTION WAS: "How do I know whether my vehicle is a SOHC or a DOHC :-).".. I just checked the basic carfax and it says DOHC :-D... I'm a bit more happy now.
Thanks a million.
Old Aug 20, 2007 | 07:45 AM
spudsterier's Avatar
spudsterier
Default RE: Best Repair Manual + Steering Vibration
the vibration could be from a worn tie rod, worn ball joint, worn tires, or the tires just need to be balanced
Old Aug 20, 2007 | 10:00 AM
das2123's Avatar
das2123
The best repair manual is the Factory Service Manual (FSM)....after that its a toss up between the Haynes and Chilton manuals.
Old Aug 20, 2007 | 04:16 PM
cerebral_mamba
Thanks, Just purchased the FSM :-).
Well, I will get it professionally checked.. hope its just a tire alignment..
Old Aug 20, 2007 | 06:48 PM
97dohc2dr's Avatar
97dohc2dr
there is a factoryTechnical Service Bulletinout for neons, i have a vibration on mine too at higher speeds and sometimes its worse than others,
the TSB says that the lower control arm bushings wear out and cause a vibration at high speeds
i haven't replaced the bushings yet to find out if it takes care of it but i bet it will do alot of good as well as the things mentioned above
check tires, balance, tie rods and ball joints, wheel bearings
Brian
