top speed
Old Aug 20, 2007 | 07:40 AM
thaguamanian's Avatar
thaguamanian
Default top speed
just curious, how fast can a built neon go? top speed wise? because i like highway racing and i was wondering if the neon is capable of going 160+mph??? i know it depends on what mods but has anyone gone that fast in a 1st gen? on a 2.0L?
Old Aug 20, 2007 | 07:47 AM
spudsterier's Avatar
spudsterier
Default RE: top speed
even with all the mods in the world, with a stock pcm the sohc will still only do 117mph and a dohc will do 130mph....you will just get there faster...
the posibilities are different with a performance pcm
Old Aug 20, 2007 | 08:10 AM
thaguamanian
where can i find a performance pcm? iim still an atx. i think moderperformance has one but it's for a mtx
Old Aug 20, 2007 | 09:40 AM
mmench's Avatar
mmench
http://www.neonrick.com/reardorr_howto.html
also if your real hard up to lighten it out. rempve the sound insulation
Old Aug 20, 2007 | 09:54 AM
das2123's Avatar
das2123
ORIGINAL: thaguamanian
There aren't many options for the ATX, but you can use an MTX one but you would need to add a transmission cooler or add a switch for your torque converter.
