Popping out of fourth Gear,,, PROBLEM STARTED AGAIN AFTER THE OIL.. HElp
i hope thats the problem i have a manual just have not read that indepth into it... and i didnt see that in the maintenence section of it or the Engine Overhaul Or The Drive Train In Which I Just Read Threw And Nowere Did I See It Talk About putting 90 weight oil into the tranny
I agree with das you do need a manaul. Hanes is ok, But I prefer Chiltons.
Anyways raise the drive's sideand put on jackstands remove the drive's side tire. There is a black plug in the trans on the front side of the trans (front of the car). Grab with a pair of pliers (long 45 degree needle nose pliers worked best for me) and pull the plug out.Use your pinky and stick in the hole. Like a dip stick. You should be able to cover your the whole end of your pinky in gear oil. If not then add some. I recommend get about a foot and a half of 1/4 inch or 3/8 inch vaccume line to make it easier to fill.
Me I just filled it up until it ran out pretty good then put the plug back in. Then clean up mess. I also recommend having a dip pan under the trans. And working with 90 weight gear oil can be fun but is worst in the winter. I would setclosed bottle inhottest water posible. The hotter you stand the easier to squeeze into your trans.
Again Thanks To All Of You But As I Said I Did Not See In The My Chiltons Manual Anywere Were it Gave Instructions To Do This...Therefore [:'(]and i did read it
ORIGINAL: boxerjl2
SPUD WHY WOULDNT YOU JUST GET A NEW MANUAL TRANNY?? instead of all the work to go auto??
there usually isnt a section in the manual about adding manual tranny oil....instead you will have to look under a section about replacing the tranny or replacing the axels
ok well today i went to napa to get some 90 weight gear oil and they said it wasnt the right stuff for my car and they gave me
AmsOil Synthetic Manual Synchromesh Transmission Fluid SAE 5w-30
they looked up my car and got that i was supposed to use this.. so do i use it or am i supposed to get the 75w-90
SPECIFICATIONS ON BOTTLE
Applications include manual transmissions and transaxles such as NVT350, NV 350o, NV 3550, NV 5600, T4, T5 and t176
Chrysler MS-9224Chrysler 4874464
Chrysler MS-9418 Chrysler 4874465
i would like to get an answer Soon so i can get this done today so please help
yeah the 90 weight stuff was $4 this was $9
well im gonna go put it then thanks to everyone that helped and i hope this works
well i dont know what that means but i think you mean the weights or watever like 5w 30
well i got around to putting the gear oil in today and it worked it no longer pops out of 4th my tranns was pretty much empty thank you guys so much for you help and as i say i learn something about this car every day
THANK YOU
TO EVERYONE
THANK YOU
TO EVERYONE
glad to help
Just remember if you have to fill it up in the winter heat the gear oil in hot water be for you try to put it in
