Question about mtx pcm
Old Aug 22, 2007 | 11:21 PM
kris95neonspt's Avatar
kris95neonspt
Default Question about mtx pcm
Ok well i tought i threw away my old 95 dohc mtx pcm when the shaft striped out inside it. But i found it in the garage today and took it all apart to see if i could get that shaft out and i did. So then i figured id put it in my project neon witch is a atx and it works but my question is. I tought it was supposed to throw the cel because of the lock converter but it didn't the number on the pcm iswritten like this.
TEH009510951
P05289716
5269 716
Is this an atx pcm?
Old Aug 23, 2007 | 08:14 AM
das2123's Avatar
das2123
Default RE: Question about mtx pcm
Did you drive the car? The lockup torque converter doesn't kick on unless you are above 55 mph or something like that.
Old Aug 23, 2007 | 12:09 PM
kris95neonspt
Ok that would explain it then i only took it to like 35 mph thanks das.I have another question what do i put on the computer board to reseal it. It looks like silcone that i had to take off to get that shaft and bolt out.
Old Aug 23, 2007 | 12:20 PM
das2123's Avatar
das2123
Not sure, but you could try some clear silicone.
