stsrting problem 99 neon
Old Aug 23, 2007 | 04:28 AM
purecty's Avatar
purecty
Default stsrting problem 99 neon
my 1999 dodge neon wont start right away at times. when you try to start it it turns ok, but acts like it is notgetting gas. wait a min. or so and it starts. it runs good after it starts. any ideas or suggestions? ty kindly
Old Aug 23, 2007 | 08:22 AM
das2123's Avatar
das2123
Default RE: stsrting problem 99 neon
Bad connection or corrosion on battery terminals. Battery slowly dying on you.
Old Aug 24, 2007 | 03:52 AM
purecty's Avatar
purecty
it doesnt drag like a bad battery, but i will try to have it checked, ty kindly. bill
Old Aug 24, 2007 | 08:49 AM
das2123's Avatar
das2123
Check the fuel pressure at the rail. Should be 49psi.
