USED OIL PAN???
Old Sep 2, 2007 | 06:41 AM
estneon's Avatar
estneon
Default RE: USED OIL PAN???
take it back to welding class and weld it up rightdepending on the size of the hole you could even put a bolt in it and weld the bolt on.....or if your a red neck you could duct tape it
Old Sep 2, 2007 | 10:36 AM
racerx55's Avatar
racerx55
take your oil pan off, clean it to no end with brake cleaner , acid, whatever potent cleaner you can get your hands on, then hose it down with laquer thinner, take a grinder across the crack to rough it up then put JB weld on it and let it set up.
Old Sep 2, 2007 | 03:38 PM
boxerjl2's Avatar
boxerjl2
you know i was thinking about using jb but ive been told that jb doesnt hold up but i know when i welded it it just heated up and cracked it in other places...
thanks racer im gonna try that tomorrow if i get the time...
right now im working on fixing the side skirt that got broke off,, but i ran out of resin
Old Sep 2, 2007 | 07:27 PM
estneon's Avatar
estneon
every time i do something with fiberglass or cf i run out of damn resin[:@]
Old Sep 2, 2007 | 11:28 PM
das2123's Avatar
das2123
ORIGINAL: boxerjl2
aluminum is what is on my car
whats the Dif?
The steel one holds a little bit more oil.
Old Sep 3, 2007 | 02:18 AM
boxerjl2's Avatar
boxerjl2
you can get CF ???
like do they have cf kits like that have Fiberglass kits??
Old Sep 3, 2007 | 02:19 AM
boxerjl2's Avatar
boxerjl2
thanks das and im sure there is a weight differance also ??
Old Sep 3, 2007 | 03:46 AM
estneon's Avatar
estneon
yeah i use jamestown distributors(or something like that) it's not cheap.........BTW i hate f-ing RABITS i just lost my stratus'sfront body kitbumper 10 minitus ago to a huge jackrabit....ok i just lost two places forbolts but i still had to put the stock one back one so i might have to order from them i can get you the price on cf....i hope i don't have to because i should have a little fiberglassleft.....i did get lucky not a drop of blood
Old Sep 3, 2007 | 04:01 AM
estneon's Avatar
estneon
heres a link to there site you can get great deals there look under fiber galss supplies www.jamestowndistributors.com
ps it's is cheaper here then i have found anywhere else and it's cheaper this month then last month i might just use cf on my bumper if i dont just get the cf version of my bumper[8D]
Old Sep 3, 2007 | 07:37 PM
boxerjl2's Avatar
boxerjl2
http://www.jamestowndistributors.com...Plain+Weave+3K
so for one yard of that is is 44.24... and a yard is 3ft by 3ft that actually seems really cheap..
i think if someone reapolstered there seats with carbon fiber that would look ausome!!!
