Oil Leak dripping from Transmission Transaxle case
Old Sep 10, 2007 | 08:49 AM
Slashwannabe's Avatar
Slashwannabe
Default Oil Leak dripping from Transmission Transaxle case
I have a small oil leak coming that I see dripping from my AutomaticTransmission Transaxlecase as highlighted below (not my engine but rather only pic I have of a Neon transmission)The leak is Engine OIL not transmission fluid, what could be leaking engine oil from back of engine? I have to add a quart of oilevery 2 weeks and I thought it was my valve seals that were bad till I looked under my car and seen this slow drip.
Old Sep 11, 2007 | 07:59 AM
spudsterier's Avatar
spudsterier
Default RE: Oil Leak dripping from Transmission Transaxle case
could be4 possibilities.....head gasket, valve cover gasket, oil sending unit, or cam sensor
