Car isn't shutting off?!
Awhile back I couldn't turn my key to the accessories point to listen to the radio anymore, no big deal.
Then shortly after I couldn't engage the starter with the key either, so I just hot wired the starter for now.
Now today, I can't shut off the car. I just pulled the coil pack connector off, and that worked fine.
Should I be looking at a JY steering column, I've tryed a different ignition cylinder right after the starter stopped working and it still didn't do anything.
What to do?
What to do?
I have found the problem, there is a pin so to speak between the ignition cylinder and the ignition switch/module, and the half of it was broken off. Thus, it wasn't turning the switch at all.
