battery to trunk
anyone have a diagram or link showing what you need to do on how to move the battery to the trunk. any help would be appreciated
RE: battery to trunk
i used some 4 gauge power wire and 4 gauge ground wire, battery clamps, marine battery box, and a power distribution block.....
take out the battery tray cut the wires off the stock battery clamps and hook them to the distribution block mount the battery box in the trunk run the power wire from the new battery location to the distribution block up front run the ground from the battery to a ground location in the trunk (i used the ground for the tail lights) and thats all i did so far... i can get pics if you want them |
pics would be nice .. whats the purpose of puttin the battery in the trunk ... i was thinkin it would be easier to rig a 3.0 for sure , also dont you have to ventilate the trunk if u put the battery in there?
You may want to put in a fuse or a circuit breaker of at least 200 amps and about six inches from the battery and one under the hood. without them could short out and cause a fire or mess up alt
It just gives you more space under the hood. What would you need it vented for? It gets alot hotter under that hood than in the trunk even with the hood vented...
ORIGINAL: Jr. Mechanic It just gives you more space under the hood. What would you need it vented for? It gets alot hotter under that hood than in the trunk even with the hood vented... |
after i moved my battery to the trunk my car has trouble starting. i got 4 gauge wire going straight from the battery to the starter? so i don't see how it hesitates. once it starts it runs fine so what could be the problem.
ORIGINAL: jakedlee16 pics would be nice .. whats the purpose of puttin the battery in the trunk ... i was thinkin it would be easier to rig a 3.0 for sure , also dont you have to ventilate the trunk if u put the battery in there? |
really....how
yea once u start a car u dont even need a battery u can run off ur alt. connect ur bat cables an go!!
haha |
