hard starting
Old Sep 16, 2007 | 03:36 PM
jfink's Avatar
jfink
Default hard starting
i recently moved my battery to the trunk and since then my car is having trouble starting like the battery is about dead. its not the battery cause it started fine before hand. I got 4 gauge wire going from the battery straight to the starter. car runs fine once it starts.?? any ideas would be highly appreciated thanks.
Old Sep 16, 2007 | 04:05 PM
12 volt's Avatar
12 volt
Default RE: hard starting
check it at autozone
Old Sep 16, 2007 | 05:58 PM
jfink's Avatar
jfink
it can't be the battery, it was fine the day i moved it to the trunk
Old Sep 16, 2007 | 06:59 PM
Jr. Mechanic's Avatar
Jr. Mechanic
Clean your battery connections, also check your new ground.
Old Sep 17, 2007 | 01:50 AM
dirt_trac_racer_80jr's Avatar
[sm=goodidea.gif]
ORIGINAL: Jr. Mechanic
the ground sounds like your problem.
