45 psi?
Old Sep 18, 2007 | 03:18 PM
justinsanders's Avatar
justinsanders
Default 45 psi?
since my injectors have been leakin (although i think i finallyfixed that problem) i figured i would do a pressure test on the fuel rail. so i did and theres a pretty steady 45 pounds. when you rev it it drops to about 40 for just a split second then back to 45 the whole time. so is that an ok amount of pressure? or is that too high
Old Sep 18, 2007 | 03:49 PM
das2123's Avatar
das2123
Default RE: 45 psi?
Stock is 49psi.
Old Sep 18, 2007 | 03:52 PM
justinsanders
Default RE: 45 psi?
o ok thanks so is 45 okay?
Old Sep 19, 2007 | 12:51 AM
jfink's Avatar
jfink
Default RE: 45 psi?
yea. if you want the 49 try changing the fuel filter or even the pump too.
