NEED HELP!! CANT FIND A PART??!
Old Sep 19, 2007 | 01:26 AM
Neon_Green's Avatar
Neon_Green
Default NEED HELP!! CANT FIND A PART??!
I have a1998 Neon, SOHC, Auto Trans. My reverse lights wont work and I have found and pulled the switch. I know what it looks like but can't find it any were?! I have found the ones for amanual trans though. I have tried looking through all the old posts and the were to buy under common questions but can't find it? Does it exist or is it called something else? I am sure I have the right switch because it is in the proper location...in the trans under the battery tray, and it has a purple black wire going to it which is the reverse wire. PLEASE HELP ME! Thanks in advance for your time.
Kevin
Old Sep 19, 2007 | 01:31 AM
jfink's Avatar
jfink
Default RE: NEED HELP!! CANT FIND A PART??!
try going to a junk yard and pullin one from there cheap part there so won't matter much if it still don't work.
Old Sep 19, 2007 | 06:15 AM
mr340's Avatar
mr340
Muscle Car Moderator
Does it look like this one?? Manual might be the same
http://www.autozone.com/R,APP970812/...ductDetail.htm
Old Sep 19, 2007 | 12:00 PM
racerx55's Avatar
racerx55
the neutral safety switch and reverse light switch are all in teh same one on ATX, ask for a neutral safety switch, it should have a 3 wire plugon it. the 2 wire plug is for the converter lockup
