GROUND WIRES
Old Sep 25, 2007 | 07:30 PM
pssssst's Avatar
pssssst
Default GROUND WIRES
hey, my car wont start sometimes from what i believe is a bad ground somewhere... the engine turns over but wont fire up but then once in a while it will start, run for a while, then die... does that sound like a bad ground? and what grounds should i be checking? thanks guys
Old Sep 25, 2007 | 07:36 PM
Jr. Mechanic's Avatar
Jr. Mechanic
Default RE: GROUND WIRES
If it was a bad ground it would not turn over or turn over very weakly. When it does not start, check if you are getting codes.
Old Sep 25, 2007 | 09:12 PM
pssssst's Avatar
pssssst
the only code i had when it did start was bad 02 sensor and i replaced that and havent been able to start it since... any ideas??? im really gettin frustrated with this thing
Old Sep 26, 2007 | 08:45 AM
das2123's Avatar
das2123
Fuel pump fuse and/or relay gone bad. Did you check the O2 wiring when you replaced the sensor?
Old Sep 26, 2007 | 12:54 PM
pssssst's Avatar
pssssst
the fuse and the relay are both fine, i checked them both... and the wiring looked good on the 02 sensore when i just replaced it ... any other possibilities??
Old Sep 27, 2007 | 09:51 AM
richardb35's Avatar
richardb35
It kinda sounds like your crank sensor...
Old Sep 27, 2007 | 11:06 AM
das2123's Avatar
das2123
ORIGINAL: richardb35
Or camshaft position sensor.
