ok, i officially am checking everything
Old Sep 26, 2007 | 10:38 PM
pssssst's Avatar
pssssst
Default ok, i officially am checking everything
alright... this will be the fourth time of posting this and hopefully i can finally figure out what is wrong with my car. it is a 96 sohc and here is exactly what happened... i started the car and it ran for about a minute..i sprayed under the hood and the car shut itself off and wouldnt restart... 2 weeks later i tried to start it without doing anything except moving all my relays around and it started the next day.... so i figured i had solved the problem with the relays.... wrong... it died 15 minutes later and still wont start... just turns over with no start.... tell me anything and everything you can think of to check for this problem because i have tried everything i can think of i need help asap!!! thanks every1
Old Sep 27, 2007 | 02:33 AM
12 volt's Avatar
12 volt
Default RE: ok, i officially am checking everything
have you checked for spark /fuel When it died did the starter still trun the engine
Old Sep 27, 2007 | 12:41 PM
pssssst's Avatar
pssssst
yes it still turns.... and it started after the first time it died.... now nothing again
