Engine or Tranny?
Old Sep 29, 2007 | 03:09 PM
neon527's Avatar
neon527
Default Engine or Tranny?
97 SOHC MTX swap, ATX ECU
At a cold start goin into second the car bogs down real bad as if the plugs were soaked in oil n had no spark, but the catch is it lasts for 2 seconds n then picks up right away, while shifting into third it does it for a split second n after that everything is okay... i put in NEW plugs, wires, upgraded to a MSD coil, changed the upstream O2 sensor, but i still have the problem n i have no CEL,
Im really stumpd guys any input would be much appreciated!! thanks
Old Sep 29, 2007 | 11:23 PM
spudsterier's Avatar
spudsterier
Default RE: Engine or Tranny?
i would highly reccomend getting rid of the auto pcm......thats ends up causing alot of problems
