oil leak
Old Oct 7, 2007 | 12:54 AM
estneon's Avatar
estneon
Default oil leak
this is for the stratus butthe same forneons too....i have a oil leak getting on my exhaust manifoldbut it's not the valve cove i just redid the gasket and it's fine(painted my valve cover too)...i think it might be the power steering hose or something like that....i asking because some one might have had this problem already and can help.
Old Oct 7, 2007 | 10:26 AM
Jr. Mechanic's Avatar
Jr. Mechanic
Default RE: oil leak
Is the ps reservoir in the same place as on a neon? I know after I did my hg I was getting oil on my exhaust manifold and it turned out to be the return line for the reservoir.
Old Oct 8, 2007 | 04:26 AM
estneon's Avatar
estneon
thanks i heard somewhere along time ago they can go bad on stratus's...and yes there in the same spot....how did you fix it?
Old Oct 8, 2007 | 02:56 PM
Jr. Mechanic
well on the passenger side of the reservoir, there should be like a 5/16 or 3/8 hose, mine was loose and spraying fluid out, or check the rest of the hoses and make sure the cap is on well. Also, check your fluid level because this may not even be your problem, but if it is low it most likely is
Old Oct 8, 2007 | 09:51 PM
estneon's Avatar
estneon
idk what it is but it only makes sence it's the ps....the whole line is covered in oil and i think it might drip on the exhaust manifold...it dose do it after a long run with lotsof streering but not when i just turn it on and sit or go in a strait line....i think i will go and check it...in the dark[&:]
