Fuel Relay
Old Oct 12, 2007 | 11:38 AM
waterman77's Avatar
waterman77
Default Fuel Relay
I have a 97 Neon and wonder if anyone has instructions that I can check out the relay with a multi meter ?
Thanks
Randy
Old Oct 12, 2007 | 08:03 PM
12 volt's Avatar
12 volt
Default RE: Fuel Relay
use a jumper wire to bypass the relay, that will tell you if the relay is working or not.
it's just an electricly activated switch
Old Oct 12, 2007 | 08:17 PM
waterman77's Avatar
waterman77
Not to be stupid but what 2 sockets would I want to jumper with the relay out ?
I think there is five posts on the relay.
Thanks
Randy
Old Oct 12, 2007 | 08:29 PM
12 volt's Avatar
12 volt
in order to find th ones that you need your going to have to use your brain. the smaller wires that connect to the relay are the ones that active the relay. the bigger ones are the ones that go to you fuel pump. use your volt meter to find the grounds and the active wires. Or you could use a long wire to go directly to your pump connector. Or you could use a wireing diagram
Old Oct 12, 2007 | 08:49 PM
waterman77's Avatar
waterman77
OK THANKS
I will try this in the morning
Thanks
Randy
Old Oct 15, 2007 | 11:12 PM
waterman77's Avatar
waterman77
OK I checked out the relay and it seems to work OK. I got a procedure from another post.
I am wondering if anyone has a wiring diagram for a 1997 Neon 2L SOHC.
Specifically the fuel system.
Thanks
Randy
