need help/advice thanks
Old Oct 13, 2007 | 04:32 PM
MINIHEMI's Avatar
MINIHEMI
Default need help/advice thanks
went to the junkyard to pick up pieces of what i thought might help with my problems
#1 i got 3 ip clusters...just in case:P
#2 i got a PCM, is there anyway to know that it will work with my car, i mean i pulled it out of a dodge neon with a atx like mine and maybe 2 years older...not quite sure...but are there other things that could complicate this?
#3 centre console air bag sensor...i pulled it outta a 97 neon it has one plug that can be inserted into it, would it be safe to try in the drive way or what?
any and all help would be vary nice thanks for your time
Old Oct 15, 2007 | 08:30 AM
das2123's Avatar
das2123
Default RE: need help/advice thanks
#1 - are you asking a question?
#2 - 95's work on 95's, 96's work on 96's, 97-99's can be interchanged.
#3 - pull the fuse for the airbags first and disconnect the battery before working on it.
