fog lights question
Old Oct 18, 2007 | 03:25 AM
MINIHEMI's Avatar
MINIHEMI
Default fog lights question
i got a old fasica from the junkyard with the option for fog lights(i guess thats a way to put it) ne ways, orginally my car doesn't have them, any suggestions as to how to make them a working part on the car, should i run wires from it and tap into the fuse box...something? need best advice, and yes i know i will need a switch
P.S. looked in haynes manual...couldn't quite find enough info
Thanks Cheers
Old Oct 18, 2007 | 09:05 AM
estneon's Avatar
estneon
Default RE: fog lights question
the wiring is in the car....look behind the bumper you will see wiring for themjust follow it and do whatever[&:]...i haven't done it because my depos don't need fog lights to see
Old Oct 18, 2007 | 03:27 PM
MINIHEMI's Avatar
MINIHEMI
ur depos?
Old Oct 18, 2007 | 05:19 PM
protivakid's Avatar
protivakid
depos are one of the many after market headlighs we can slap on our neons.
Old Oct 18, 2007 | 05:42 PM
neoncrazy101's Avatar
neoncrazy101
heres a problem though. not all Neons came with the wiring INSIDE the car. so you would have to figure out how to run that part of the wiring. i was going to swap my my dads fog bumper onto my car until i realized that i dont have the wiring inside the dash for fogs.
Old Oct 18, 2007 | 08:08 PM
tattoojack's Avatar
tattoojack
also if they didnt come on there stock and you dont have the wiring, you wont have the switch that goes next to the defroster
Old Oct 18, 2007 | 08:10 PM
neoncrazy101
ORIGINAL: tattoojack
thats easy though. you just buy one. you can take it out in like a min.
Old Oct 18, 2007 | 08:48 PM
MINIHEMI's Avatar
MINIHEMI
ok so i have a question with the headlights then, mine are kinda frosted, and i am taking the fasica off hopefully before winter, is there anything i can do to unfrost them, cause currently one headlight is brighter then the other lol
Old Oct 18, 2007 | 08:54 PM
neoncrazy101
if you just want them to look clear for a little while then you can clean them with CLR or something and alot of elbow grease. but its easier to just buy the Diamond Clears from Modernperformance.
Old Oct 18, 2007 | 08:58 PM
MINIHEMI's Avatar
MINIHEMI
don't think modern performance exsists In canada, and how would it cost to get them cause, i am a college student...
