Engine whines at startup
Old Oct 20, 2007 | 09:40 PM
l33tn3wb3r's Avatar
l33tn3wb3r
Default Engine whines at startup
Sometime's when I start my car, it turns over, but dies. Sometimes when I start it, it'll run just under idle, and OTHER times, a belt will whine. I'm not sure if it has to do with my sound system, my new exhaust and header or what. Here's a link to a video I posted on myspace of the whining sound if someone could be kind enough to take a look at it. Thanks in advance.
http://vids.myspace.com/index.cfm?fu...deoID=20464206
Old Oct 21, 2007 | 12:58 AM
12 volt's Avatar
12 volt
Default RE: Engine whines at startup
your alternatorbelt is loose. you can tighen it and it sould fix the noise, i would get a new belt.
