Cooling propblem update....more help please
1999 2.0L SOHC...
Overheats and loses all coolant when driving after just 10 miles.
Idles at normal temp fine for at least an hour without loss of coolant.
Both fans inoperable currently.
No oil in coolant or vice versa.
No extra tailpipe emmissions.
Any ideas?
By the way, where is the radiator, or coolant evacuation valve? I need to let out some coolant.
Any ideas?
damn man i told you in the other forum the fan relays are cheap as hell from any autoparts store. fix the fans and your water wont boil off! thats all! fans are mandatory!
and the drain plug is on the passenger side bottom of the radiator.
Check to make sure the system holds pressure and not leaking anywhere all it takes in a a pin hole. Also woulden't hurt to checkif you havean MLS head gasket. all 99 models should have them but some don't. 09-08-99 is the mopartechnical service bulletin that talks about the MLS install
