coolant overflow bottle
Old Oct 21, 2007 | 07:23 PM
wallacereid's Avatar
wallacereid
Default coolant overflow bottle
Is the coolant system supposed to suck coolant out of the overflow bottle, if it needs it? If so, them what would cause it to not suck coolant from the bottle?
Old Oct 21, 2007 | 10:07 PM
unclemike's Avatar
unclemike
Default RE: coolant overflow bottle
A bad radiator cap.
Old Oct 22, 2007 | 01:10 AM
tattoojack's Avatar
tattoojack
or water pump
Old Oct 22, 2007 | 09:50 AM
spudsterier's Avatar
spudsterier
here is what happens....
when your car builds up pressure in the coolant system, the pressure pushes the plunger on the radiator cap.....the plunger will then no longer block the hole going to the overflow tank and pulls or pushes the coolant into or out of the tank......if your not getting the coolant back then it is a bad cap or a non efficient water pump
