Clutch Time.
Old Oct 24, 2007 | 04:12 PM
neoncrazy101's Avatar
neoncrazy101
Default Clutch Time.
looks like my 97 Neon is in need of a new clutch. if i get pass 75% throttle in 3rd,4th or 5th, the RPMs just go crazy but yet i dont go anywhere. on my 95 Neon that is in pieces, it has a clutch with less than 10k on it. how do i go about finding out if my 97 has the same type clutch as my 95? cause i would love to save the money and just swap the clutches. but if their not should i just upgrade the clutch to the PT clutch? cause its a direct swap right? or do i have to modify the clutch?
Old Oct 24, 2007 | 04:27 PM
spudsterier's Avatar
spudsterier
Default RE: Clutch Time.
no matter what style clutch you have in the green car you can always swap it into the other one.....
if it is a different style clutch then all you have to do is change the fly wheel with it
Old Oct 25, 2007 | 09:21 PM
neoncrazy101
any special tools needed?
Old Oct 25, 2007 | 10:51 PM
spudsterier
if its a non modular clutch that you will be using then you will need the alignment tool....but i have aligned the disc without the tool before....
other then that its just your basic tools that are needed
Old Oct 26, 2007 | 10:48 AM
neoncrazy101
about how much is that tool?
Old Oct 27, 2007 | 09:47 AM
spudsterier
im not sure, i think its only a few bucks
