question on lug pattern
Old Oct 28, 2007 | 10:23 PM
dodged200's Avatar
dodged200
Default question on lug pattern
Hey, I just bought a 95 neon with a five lug bolt pattern, and I want to make it the 4x100. What do I need to change to make this work?
Old Oct 28, 2007 | 10:26 PM
mulletman11's Avatar
mulletman11
Default RE: question on lug pattern
my 95 is the 4x100 size
i would say lug conversions, if they make one that szie
why do u want that suze anyway?
Old Oct 28, 2007 | 10:33 PM
95to96transplantneon's Avatar
The 4x100 lug pattern is very popular due to 95 percent of all hondas have the same lug pattern. 5x100 is harder to come by.
dodged200's Avatar
dodged200
I bought some wheels for a car I'm about to sell and they are 4x100 and I knew the neons had 4x100 and 5x100, so I just figured that I would convert it to the other while I'm tuning it up and changing some suspension. Didn't know if I just needed to change the hub or the whole shaft or what was up. Thought I would ask before I dug into it to make my life a little easier.
Old Oct 28, 2007 | 10:49 PM
neoncrazy101's Avatar
neoncrazy101
just the hubs.
Old Oct 29, 2007 | 10:29 AM
spudsterier's Avatar
spudsterier
actually.....you need to change the hubs (have the old one pressed out and a new one pressed it) but you will also need new front rotors and new rear drums....just dont forget the rotors/drums otherwise you will end up with rims that will work, but brakes that wont
unless you have rear disc brakes....then you will need everything to convert them to drum brakes becasue they didnt make the disk rotors for a 4 lug....only 5
