dual side exhaust
Old Oct 28, 2007 | 10:43 PM
mulletman11's Avatar
mulletman11
Default dual side exhaust
on my 99 r/t the cat is bad
i have a high flow cat from mangnaflow and as long as im changinf that i wanna put a new exhuast on
both me and my dad are good at welding and we have all the tools, so i wanted to get some opiions on this.
after the cat i wanna branch 2 pipes, one the each side, then two of each of those and chrome the tips and set the exhaust ends right b4 the tires?
opinions? its completly legal for pa and clearance issues wont be a problem.
Old Oct 28, 2007 | 11:03 PM
kris95neonspt's Avatar
kris95neonspt
Default RE: dual side exhaust
I know the srt guys have a one exit exhaust on the drivers side and the reason for that is because the fuel line runs on the pass side and could cause the car to catch fire but thats just what i heard and don't know if it true or not. Maybe one of the other guys on this fourm could tell you if thats true or not.
Old Oct 29, 2007 | 04:04 AM
boxerjl2's Avatar
boxerjl2
i thought about the same thing but just dual on one side and have it molded into the side skirt i think that would look tough but idk
i like the idea
Old Oct 29, 2007 | 05:24 AM
HabitatHxC's Avatar
HabitatHxC
yea a fellow srt driver had this and he wrapped the one going out the passenger side with heat wrap and stuff. Its all in what you want to do!
Old Nov 12, 2007 | 11:44 PM
dcmcguy's Avatar
dcmcguy
i think that would look cool, but it wouldnt sount that good i dont think....it sounds much better on a v8
Old Nov 13, 2007 | 08:44 PM
tranyinstaller's Avatar
tranyinstaller
if u ran a large enough collector it would sound alright, but still clearance would be an issue. i thought about doing just what ur talking about till i got the car up on the lift at my work. the pas. side has like no room to run the pipes. especially if u intend to lower the car like u were saying on ur other post. i ended up using a good old cherry bomb glass pack upstream and ending the tube just to the inside and rear of my tire on the driver side. you dont see any pipe out the rear ( which i kinda like). also its loud as hell. the only bad thing is that i dont have any flex tube in there, so when i hammer the throttle my exhaust hits the floor. also i guess it doesnt help that the exhaust runs through a tight space between my frame brace and the channel. the frame brace much like my entire exhaust also of my own making : )
