bad wire somewhere. if you changed the relay and it has power, but the fan is not gettin juice make sure its not the fan itself. hook power from the battery, see if it spins.
wired the motors direct they both work i bought this car blown up so i don't know if they ever worked 98 dohc air cond. cycles on and off a lot i know the fans are supposed to come on with a.c.added a can of 134 no difference thnx for reply jack
