timing belt and power steering pump
Old Nov 21, 2007 | 01:04 AM
Captansavaho's Avatar
Captansavaho
Default timing belt and power steering pump
I want to put on another timing belt and also my power steering pump is noisy when i first start the car then it gets alot quiter.....anyways about how long would it take to do both? My pops owned and ran a car lot for along time and is a pretty decent mechanic. so for someone with expeireince about how long would it take.
Old Nov 21, 2007 | 02:16 AM
Slashwannabe's Avatar
Slashwannabe
Default RE: timing belt and power steering pump
I did it in about 4 hours but I was chasing tools most of the time so somebody with everything at their disposal should be alot quicker. Also change the water pump at the same time or you'll regret it later.
As for the Power Steering pump if it works fine I'd leave it, mine is noisy but only when its cold outside and it will only make noise for about less than a minute, it works good still. The Power Steering Pump comes off at the same time the rest of the **** for the timing belt does so it isn't any extra time to change it, I took my pump off its mounting brackets and left the hoses on and tucked it up by the head so it was mostly out of the way.
Old Nov 21, 2007 | 08:58 AM
spudsterier's Avatar
spudsterier
for an experienced mechanic, timing belt replacement isnt bad at all.....usually takes me about and hour on a dohc and 45 minuites on a sohc....that included changing the water pump and idler pulley(s)
Old Nov 21, 2007 | 09:12 AM
hnda8r's Avatar
hnda8r
Dam thats pretty dern quick there. Come over an do mine Pizza, and Beer. J/K
Old Nov 21, 2007 | 04:42 PM
spudsterier
too far of a drive...otherwise i would
Old Nov 21, 2007 | 11:32 PM
stevedak's Avatar
stevedak
You gotta take the p/s pump off anyway, why risk having to go back and do it again later. I've got a perfectly operating pump on ebay for $9.99 See item # 280175654584
