Window Leaking
Old Nov 21, 2007 | 08:40 AM
TigerofH's Avatar
TigerofH
Default Window Leaking
Hey. I've got a 95 Neon, and when I hit speeds around 60+ miles an hour, my window seals start to leak. THis wouldn't be bad if I didn't have a 5 hour drive everytime I need to get home. Anyone know of any fixes they make for this? Any help would be great. Thanks.
Old Nov 21, 2007 | 03:15 PM
95to96transplantneon's Avatar
Default RE: Window Leaking
Um... where is it leaking possably take a pic of the area...I'm pretty sure I know where your talking about but show us... also is it a 2 door or a 4 door....
Old Nov 21, 2007 | 06:44 PM
tattoojack's Avatar
tattoojack
either your window supports are failing allowing the window to flex more than usual, your door is out of line which you can fix by loosening the hinges and relining, or your weather stripis bad. either way. easy fix.
