i did search...alot
Old Nov 21, 2007 | 09:40 PM
estneon's Avatar
estneon
Default i did search...alot
well i almost have my turbo done but i want to relocate the battery...know i know how to do alot of it but...i have two questions
i know i need a in linefuse but what size and what wire needs it?
Old Nov 21, 2007 | 09:52 PM
hatchetman2590's Avatar
hatchetman2590
Default RE: i did search...alot
igot a 2 gauge wire, and the old cables grounded the negative and tied the pos into the new cable and it works y do u need a fuse
Old Nov 21, 2007 | 10:35 PM
rtneon67's Avatar
rtneon67
i wouldnt use a fuse. if you run the wire right you shouldnt need one. but if you want one i would be a circuit breaker. plus its going to hve to be around 200 amps. your starting system can pull like 150 to over 200 amps.
Old Nov 21, 2007 | 11:35 PM
tattoojack's Avatar
tattoojack
200 from a car stereostore. you want a fuse next to the battery before the wires go under the carpet in case you get a short. this will prevent your carpet from catchin fire. BAD IF YOU ARE DRIVING WHEN IT HAPPENS CUS BY THE TIME YOU NOTICE, YOU ARE SERIOUSLY ON FIRE!
Old Nov 21, 2007 | 11:56 PM
estneon's Avatar
estneon
thanks guys i will order this stuff soon
