Little trouble with my push button start
first are all your wires yellow?? anyways just take the instructions and place it on a table facing up, then take your switch and hold it the same way as the picture then that should help. take a wire and connect to terminal top right(going off picture) and ground it. then take a wire and connect it to the top left terminal to a positive source(red wire in ignition switch wiring harness), you'll then want a wire going from the bottem right terminal to the previous wire(going from top left to positive source). just tear off the insulation and wrap the wire around followed by electrical tape.the last step would be to take yet another wire and go from bottom left terminal to your ignition wire that runsfrom ignition switch wiring harness(i beleive it is yellow). after that push the bottom and hear it start. any more questions i'll try and help. i sent you a PM with a modified version of the instructions hope it'll help
Its all yellow wire because i bought a package of 12 gauge wire colors dont matter felt like going yellow for the ignition yellow
your paragraph confuses me but your pm seems very helpful
with the red wire just splice it? or cut it completly like the yellow ignition wire?
ill play around with it tomorrow and let u know how it goes
I got it to work and than i went to wrap up all my wires and plug the harness back in and it didnt work[:@]
i messed around and realized the harness isnt working somehow.It still makes the noise with my door open and the key on the "on" postition but the radio doesnt come on
So i cant start my car at all now. [:@][:@][:@][:@]
I listened to ziggyneons page which is the worst thing i could have ever done. Didnt help at all if anything it made things worse.
My problem now is everything works except my ignition and my radio when the car is on the "on mode" maybe i slightly pulled the yellow wire out of its place and it wont work not after messing with it so much. i dont know but i do know my car wont start and the radio doesnt work but it seems everything else does.
checked the fuses none were blown
As i said i got it to work i went to wrap up all the wires and such than i tried and it didnt work i was confused later on i found the radio would come on when in the on mode but my cig lighter works my dash lights work headlights all work
All wires are connected too maybe not with the full extent of original wire (in thickness) but thier connected. I have no idea
first off thats is horrible instructions. the only real information in there is hooking the ignition wire up. if your button is cheap it won't "know" if the car is on, you will. so you shouldn't have to mess with any ACC. wires ifyou did that should be the root of yourproblem with the radio cause the ignition wiring harness as two or three ACC. wires. i beleive one is for the air and the other(s) is for the radio, turn signals, etc. your switch requires 4 connections; 2 power wires, one ground, and one ignition. no ACC. hope this helps.
