Clutch removal.
Old Dec 1, 2007 | 11:49 PM
neoncrazy101's Avatar
neoncrazy101
Default Clutch removal.
I dropped my transmission out of my old Neon...but how do i get the motor not to move so i can actually get the clutch off?
Old Dec 1, 2007 | 11:51 PM
Aerorat's Avatar
Aerorat
Default RE: Clutch removal.
Did you unbolt it from the fly wheel
Old Dec 1, 2007 | 11:53 PM
neoncrazy101
ORIGINAL: Aerorat
nope cause the flywheel kept moving. and i really cant afford damaging the flywheel nor clutch cause i need them in my other Neon. (both have less than 10k miles on them)
Old Dec 2, 2007 | 10:13 AM
spudsterier's Avatar
spudsterier
put a breaker bar with a 3/4" socket on the crank pulley bolt....thatway you can hold it stillwhile you unbolt the clutch
Old Dec 4, 2007 | 11:31 AM
Ghost Neon 2's Avatar
Ghost Neon 2
You will need an 18mm wrench or short socket to remove the flywheel bolts. A breaker may be required.
