Swapping 1st gen Gauges
Old Dec 3, 2007 | 09:53 PM
mopar99's Avatar
mopar99
Default Swapping 1st gen Gauges
My neon unfortunally is an automatic hope to change that but right now i currently dont have a tach in my gauge cluster. I was wondering if i could take a gauge cluster out of another neon that has a tach and weather or not is the wiring already there for it just not being utilized. I understand that id have to change the odo but would i be able to just swap them and it would work or not.
Old Dec 3, 2007 | 10:33 PM
95to96transplantneon's Avatar
Default RE: Swapping 1st gen Gauges
you can just take out the 4 screws holding it in pull it out and put the new one in. Thats all you have to do and it will work just fine...so yes all 1st gen clusters connect the same and even though you dont have a tach the tach wire is there...
Old Dec 4, 2007 | 12:00 AM
mopar99's Avatar
mopar99
So allthree guages i originally had will still work as well as the tach will work also even though there wasnt a tach to start with. Thats what you were saying correct.
Old Dec 4, 2007 | 12:42 AM
mopar99's Avatar
mopar99
Sorry i just looked a little further for the gauge swap andIfound it. I appretiate the help. Thanks
Old Dec 4, 2007 | 09:55 AM
das2123's Avatar
das2123
Swap away and enjoy. They are plug and play.
