NAME THIS CLUTCH!!!!
Old Dec 5, 2007 | 12:58 AM
95to96transplantneon's Avatar
Default NAME THIS CLUTCH!!!!
Ok guys I need to know if this is a modular or non-modular....
Spud said if rivits hold it together its a modular and if bolts hold it together....All I see all the way around is What "looks" like rivits no bolts to speak of Had wife sit in car and tap the starter with the key to turn the clutch and all i saw was what I have circled in the pics....
So witch is it???? need to know asap...
[IMG]local://upfiles/61619/E0E14F9D693D4FAAA782C2594AA28B50.jpg[/IMG]
[IMG]local://upfiles/61619/D44027D6CF0946A781420DB50B9E4F38.jpg[/IMG]
[IMG]local://upfiles/61619/ABDDCE7015294140A6E2F360BDB43348.jpg[/IMG]
Old Dec 5, 2007 | 08:24 AM
hatchetman2590's Avatar
hatchetman2590
Default RE: NAME THIS CLUTCH!!!!
from wat i can see from the pics it is a modular clutch
Old Dec 5, 2007 | 08:41 AM
spudsterier's Avatar
spudsterier
looks like a modular
as long as the parts you circled are round headed and not hex headed, its a modular
Old Dec 5, 2007 | 02:40 PM
there round headed....so i guess its modular...oh spud.... I couldent find the inspection plate you were talking about.
Old Dec 6, 2007 | 02:41 PM
tranyinstaller's Avatar
tranyinstaller
yah its modular and although u can see that round head, the easiest way to tell is that their is no ring gear on the fly wheel for the starter to engage. plus if you look to the block side of it you can just barely see the flex plate.
Old Dec 6, 2007 | 11:55 PM
spudsterier
the inspection plate is on the underside of the motor on the tranny end....
its the plate you take off to undo the flywheel bolts...and the same plate that oil leaks out of when your rear main seal is going bad
